Andy clarke
- Stockbridge
How easy is it to swap mechanical discs for hydraulic? Can I just put levers lines and calipers on?
Thanks il check some of these places and have a good lookShop around, but there are some absolutely fantastic deals on Shimano Deore BR M615 brakes at the moment, about £60 for some of the best brakes on the market. Even cheaper if you get them from abroad, Alltricks.fr, hi-bike.de, probikeshop.com, Rosebikes.com. Just be aware that they will come euro setup, so front brake left hand. You'll probably need to shorten the hoses anyway, and can swap the hoses over when you do.
Just be aware that they will come euro setup, so front brake left hand. .
The hoses are very fine bore, so the fluid's viscosity helps. You lose perhaps a couple of drops, but you can compensate for this by pushing the pistons out slightly, thus lowering the level in the reservoir. When you trim the hose, some fluid goes with the off cut, but when you reattach the hose and push the pistons back in, any air int he first cm of the hose is displaced into the reservoir. I've done at least half a dozen pairs now, and only ever had to bleed one brake after shortening and swapping.How do you shorten the hoses without getting mineral oil everywhere?
No, not if you're carefulCool - doesn't it leak out from the reservoir as well though?
