Like Ian, my commuter (Trek Portland) is drops with discs- in my case, Shimano BR-R505s. As RAFN has noted, you'd need new brakes as well as shifters. Shimano's tech document for my brakes states:
"Use 2.5 finger levers for canti brakes such as the BL-R770 or STI levers such as the ST-6600 for road bikes as the brake levers. Do not use in combination with V-BRAKE brake levers. If used in combination with V-BRAKE brake levers, it will not be possible to obtain sufficient braking force. If using in combination with 4-finger levers such as the BL-T400/ST-T400, the braking force will be higher. Accordingly, under some conditions such as certain riding positions or overall weight, the bicycle may fall over and injury may result if proper care is not taken."
