Custom24
- Oxfordshire
Hi
Shimano XT front disc brakes. No problems for the last year.
Then I changed the pads 2 days ago and now I cannot get it to stop squeaking. Very slight, but annoying. Happens not while actually braking, but just while riding along. Also a regular clicking.
I've used Uberbike sintered pads because I'm a cheapskate, but these have been fine on the rears.
I've done the tie the brake lever to center the calipers and then tighten the hex nuts thing, several times.
The squeaking seems to be gone when I adjust, but then returns during a ride.
I can see by sighting that the disc is in contact with the non-hydraulic side pad with the brakes off. I can't seem to tigthen the caliper so that this is not so.
Disc isn't warped - can't see any movement while sighting and wheel is rotating.
I pushed back the pistons inside the calipers - you have to with new pads. I'm not sure if both are supposed to move, or just the one on the hdyraulic side?
Do new sintered pads just do this and I have to wait for it to go away? Have cycled 20 miles on the new pads.
Copper grease? (Although I think that's just for squealing under braking?)
Stump up the money for Shimano pads?
Keep fiddling with it?
Any other ideas?
Thanks
Any other ideas?
Thanks
