swee'pea99
My wife recently bought a b'twin electric bike and loves it, but she reports that her front brake has stopped working properly. I've recently replaced the cable, and I know it's fine. The mech seems to be working fine, and if you use the brake while spinning the wheel in the air, it stops immediately. But if you push the bike on level ground with brake fully engaged, it slows the wheel slightly, but not much, and it's not hard to push through.
I really don't know where to start - I've only ever worked on caliper brakes. If it helps, it looks like this:
Worn pads? I guess would be the obvious place to start. But maybe I'm wrong. If it probably is pads, are they easy to change? Is it intuitive? Are there tiny little springs that will leap across the kitchen the moment I loosen a screw? Do I need to get Tektro pads, or are disc brake pads standard sizes? Or might it be something else entirely? And all points north.
Any hints & tips much appreciated.
