Disc Brake Snatching Advice Please
Hi all I have a cx bike and today the rear disc brake started working really well way better than before with virtually no modulation, it's either on or off. Could this be due to muck contaminating the pad's, if so what's the best easiest solution.
MacB
Need a few more details like if the bike is newish, how many miles current brakes/pads have done, what performance was like and what it is like now, make and model of brakes.
2old2care
2old2care
Hi the bike is 3 weeks old and has covered about 60-70 miles, the make of brakes are Tektro Lyra mech discs, performance when new was on a par with road rim brakes , but now the rear brake bites like a goodun, and is now better than my Campag Veloce 9spd brakes ( not the rim brakes mentioned above :wacko: ) which up to now were the best I've used. Cheers 2o2c.
MacB
Aha, ok well disc brakes have a wearing in period before they reach full effectiveness so a noticeable improvement in performance would be expected after that sort of mileage. I'm not personally familiar with the Tektro model but I do use mechanical disc brakes, the Avid BB7s. Unlike hydraulics(or at least the better ones) they aren't self adjusting so setup and maintenance are more of a manual process. I followed these instruction for the BB7s:-
http://www.twowheelblogs.com/avid-bb7-disc-brake-set-and-tuning
Obviously the Tekros will differ but just reading that, and familiarising yourself with the sort of terminology, should help your understanding. It also depends on how much you want to do/learn yourself, nothing wrong with relying on your local bike shop. Basically mechanicals will rely on one pad moving and pushing/bending the rotor onto the other pad. The bite point and modulation will be influenced by where the rotor is within the caliper, ie central or more to one side or the other. You'll probably have adjustment at your levers and there is also the potential for loss within the cable system. As things wear you'll need to adjust the pads to compensate for this. Depending on the type of pad, organic/softish ones wear faster than metallic sintered, and type of riding/conditions will decide how often this needs to be done.
It all seems quite complicated at first but I'd say it's worth getting as familiar with these sorts of brakes as you would with a rim brake. I have seen some negative writeups around the Lyra brakes but without having messed around with a set myself I can't tell how much of that is down to setup issues. I do know of one potential problem where the brake releases when used hard, if you experience that then get them returned and swapped out. The BB7s are currently considered the best of the mechanical brakes(don't bother with BB5s) but if you swapped to hydraulics(I'm guessing not, due to drop bars) then the Shimano Deores get great reviews around price and reliability.
2old2care
2old2care
It's definetly a noticeable improvement, if the front brake improves the same I'll be over the handlebars. I think it may be contamination as it happened after a rainy day and the muck on the bike seems to be a little bit sandy. Anyway I'll take it back for it's 6 week checkup and ask the mechanic about it.
I was going to upgrade to BB7's in the future, but now I don't see the need, I wanted decent brakes and now I've got them, just need to order the Marathon Winters now.
Many thanks for the advice MacB :biggrin: :biggrin: :biggrin:
spence
Northants
As MacB, the pads and disk have just bedded in, it's what you want them to do. The sandy paste will defo help the process, some recommend it as a way of speeding up the process. Just stop yourself from grabbing handfuls of lever, you don't need to now.
MacB
Yep, a bit of 'gentle hands' doesn't hurt, if you're used to hauling on an underperforming rim brake then the discs can be a bit of a shock. Good luck with the bike checkup.
