Disc brake rub
Moodyman
I have Hydraulic disc brakes and the rear is rubbing.
But it only rubs down long fast hills where several stages of sharp braking may occur to manage speed.
About 200 metres after the braking stops, the disc stops rubbing.
There's no rubbing in the workstand or in normal travel incl. light braking at junction stops.
The braking surface on the rotor is very thin. Not measured it but it feels less than half that of the main body of the disc and considerably less than the front disc which doesn't rub.
Am I right in concluding that the rotor is too thin and therefore overheating (less metal) and warps during long descents which leads to rubbing, and returns to its normal position when it cools during pedalling.
I've done the usual checks - rotor is true, wheel sitting correctly in the dropouts and the pads have been removed and reinstalled after the pistons have been checked.
I might add the rotor has done c. 10k miles and I'm a heavy rider in a hilly area.
Loch side.
How about a picture of the disc. In focus please.
Moodyman
Moodyman
New rotors were acquired a couple of weeks ago. Being a Yorkshireman I thought I'd check all other avenues before swapping them.
Regarding pictures, there is nothing discernible that a picture would show. I can not only feel but see a significant ridge between the main disc body and the braking surface.
A job to do at the weekend me thinks unless I've overlooked another factor.
Loch side.
A pair of dental calipers, available for a few quid on eBay would be good for measuring the thickness. They are also good for checking the remaining thickness of rims, to help decide when to retire them.
Damn! I never even knew that a dental caliper is a thing. The obvious question is why would one want to measure teeth? For the answer, I turned to Google, which directed me to Youtube and now I'm not only an expert on measuring teeth but went to Wikipedia to learn about Boley and then back to Utube for some follow-up training and to eBay to order one of them tools and one thing lead to another. I'm now learning Indian Pole Dancing. What a day!
