thanks for all your input, the front disc brake has come with the mount, and I have now ordered my rear adapter mount using the link you provided.
Thanks a lot
Both the bike and calipers are flat mount so you'll need the front adapter regardless of rotor size used, for the rear you only need an adapter if you are planning on using a 160mm rotor otherwise you can mount the caliper directly onto the frame.
One point to note is that you will need to get the caliper mounts faced properly - judging from the photos you posted above this hasn't already been done. If you don't then it won't be possible to get the calipers aligned properly. You
can do it yourself to an acceptable degree with fine gauge files, but it takes quite a bit of trial and error to get it right, your LBS should be able to do this and I'd recommend you ask them to.
