Disc brake adjustments
gaz
Cycle Camera TV
South Croydon
My rear brake is playing up. At first there was too much lever needed to make the pads make contact with the disc. So I adjust the cable so that i needed to pull the lever less to get some bite
But now, if I pull the lever too hard then there is a ping sound and the rear brake disingages and it will only bite again if I readjust the brake cable. I've checked that the cable isn't slipping and that the cable isn't catching in the tube.
Everything seems fine.
Anyone know what this issue is?
