Dirty Chain
Hi there
I thought I had cleaned my winter bike properly before storing it away at the beginning of the year but obviously I haven't.
The chain is brown and hard.
What is the best way to clean the chain and get it back to normal?
Paulus
Barnet,
Hi there
I take it that it is rusty.
You might be able to restore it, firstly with plenty of wd40 or penetrating oil, spray it liberally on, and then with a toothbrush work it in to all the links and pins. Then wipe it all off and then repeat, several times until it is free.
Then, once it is clear of rust, clean thoroughly with chain cleaner, wiping it clean , and finally use a chain lube letting it get into the pins and rollers, before more wiping and cleaning.
Check the condition of the Chainrings and sprockets for rust and dirt.
Of course you could just buy a new chain.
It’s possible that cleaning it is what caused this. After cleaning it you need to oil the chain otherwise it can rust.
Exactly, and make sure it's coated all the chain - this is usually where an aerosol lube is useful if the bike is going into 'storage' rather than being used as the lube won't spread if not used.
richardfm
Cardiff
Before doing all of that I would remove the chain from the bike and use a wire brush to remove as much rust as possible.
  • Like
Reactions: C R
