Different width tyres?
J1888
Slightly odd question, but would there be any detrimental effect in running 25mm on the front and 23mm on the back?
Same rims front and back, but asked my old man to pick me up a new tyre and he's ended up getting me a 23mm, not a 25mm.
S-Express
No particular issue, but personally I would switch them so that the 25 is on the rear.
Pale Rider
I hadn't thought of that, but it's a new tube too, so that's thankfully not an issue.
Job should be a good 'un.
The problem I had was getting a tube used in a 2" tyre into a 1.75" tyre.
Proportionally a bigger difference than your case, but if I were ever dropping a tyre size again, I would buy a new tube to go with it.
mjr
I have never come across a tube that takes on a new size after inflation.
Funny you should say that... are you stalking me?
It's not quite the same, but one of two strange new things I suffered last week was a tube that seemed to have taken on a new, larger diameter after a puncture or rather a series of punctures - the other strange new thing was a sharp object getting between rubber and casing, leaving a bubble in the tyre that it could hide in and then pop through the casing and cause a new puncture, which was rather annoying and left me pushing the bike home after a series of failed repairs. Anyway, I've no idea how a tube ends up longer, I don't remember seeing it ever before and it really was the correct size when it went in.
Anyway, back to the original question: no, no problems, especially not with only 2mm difference. I'd usually put the wider on the back. One of my bikes currently has 28mm front and 37mm rear, to try to give a nicer ride without stuffing the handling... not entirely successfully, though ;)
davidphilips
Phil Pip
Onabike
why not just take the tyre back and see if shop will exchange it for a 25mm.
Ajax Bay
East Devon
How many patches did the tube have on by this time? You have separately said that you patch them till they bleed and that you patch patches. Perhaps this is the tube's way of telling you to retire it.
mjr
I usually stop short of patching patches (but it has been known) but the tube did have at least six. It's raining and I'm not going to the shed to look! :laugh:
Loch side.
Check your rearview mirror. See those lights....
I've abused a few tubes in my day in an effort to force them to reveal the slow puncture. Usually they end up looking like a python digesting a goat but return to nice slender vine snakes once the air is released. I'm off to the shed right now to inflate the bejeezus out of one and I'll leave it overnight. Let's see what happens. This would exaggerate the notion of a 23mm tube inside a 25mm tyre taking on a new size.
Each time I inflate a tube without a constricting tyre I marvel at how the diameter and length of the tube increases but tyres (essentially high pressure hoses) don't do it thanks to those cords inside crossing at exactly the right angle. Get the angle wrong by half a degree and your tyre chances diameter with inflation.
Anyway...I'm with you on patching patches. I only discard a tube if the valve stem detaches or I really botch a patch on a patch on a patch.
si_c
Wirral
Just a quick comment, should be no problem to run the 23mm front, 25mm back, with the caveat that your internal rim width is sufficiently narrow to run 23mm tires safely. Check your rim specs, my wheels for example are 17mm internal width, and recommend a minimum 25c tire.
