Different brake types
gambatte
Middle of the pack...
S Yorks
How much pull on Vs? (mm)
comparatively:
How much pull with centrepulls?
Doing up a bike with centrepulls, levers a bit ratty and I've got some decent V levers.
Compatible?
02GF74
I can remmebr when V-brakes first came out and they were incompatible with the centre puill levers - not enough pull - there was some gadget you can attach to the cable to alter the brake pull.
you are going the oppositve (centre pull with V-lever) so presumably ytou will have hte oppostite problem - too much pull?
try it, if it doesn;lt work, you can buy V-brakes really cheaply as disc brakes is what is in vogue.
MartinC
Cheltenham
V Brake Levers about 25mm or more of cable pull. Non V Brake 13-15mm. Centrepulls won't have much power if you use the V Brake levers.
