Diadora Bomba 09
Scrub
Tyrone
Hi
I was hoping for thoughts on this bike that I am thinking of purchasing.
The bike is a Diadora Bomba 09, not sure what that means but the frame is a dedacciai 3k 09.
The groupset is Campy Record 10 sp with MOst carbon crankset. It has Remerx RCX wheeleset ( which aren't on it in this picture) which I am told is the equivalent of something like Fulcrum 1's or Fulcrum 3's.
The bike has a Prologo saddle, with alloy bar and headset and a couple of carbon cages.
The guy is looking £2500 for it.
As always, all thoughts are appreciated.
I'm sure that you know that Diadora is an Italian shoe maker. I don't think they have branched out - so it will be a re-badged something or other. The wheelset is also an unknown property.
As I see it you are paying out top whack for a largely unknown proposition and I suspect it will be hard to shift if you find that you have bought a pup.
A quick back of the fag packet calculation would put the cranks £200 , Levers and 2 mechs £400, wheels £300, and finishing kit say £300. So the frame is £1300! (and that is assuming the Pinarello brand cranks are any good and that there is no damage to the levers and mechs etc etc.)
S
Scrub
Tyrone
Cheers, trying to google info on this bike and any of the kit draws as good as a blank
HovR
Plymouth
Googling the name "Diadora Bomba", and the top result is this thread! I would say that is probably not such a good sign in itself.
For under 2500 you can get a carbon bike with full Ultegra from a big name like Pinarello, brand new, from a reputable dealer (Link). If you have that much money to spend, might as well play it safe.
