Di2 Front Shifter - not springing back - fix or replace?
DSK
I was giving the bike a once over on the weekend and noticed, that somehow, whilst the bike has ben parked up in the garage, the left hand side shifter for the front mech has an issue.
It still works fine and allows you to switch between the cogs. However, when you shift onto the small ring, the lever/button doesn't return to its normal resting position. I have to just nudge it with my finger. I have had a look around it and cannot see anything obvious. Does this sound fixable or do I need to get a new shifter? (I believe the kit is 6870).
