Any ideas of the cause of this problem? On my Campag triple I can't get the biggest sprocket in middle ring or granny because the top of the rear derailleur cage rubs on the sprocket teeth.
It's definitely nothing to do with wrong size of cage or incompatible cassette - I have had this setup for five years and it's only developed in the last few hundred miles. Ditto chain length, I'm fairly sure.
I have had the cables renewed so cable stretch is a possibility, but that hasn't affected it before. I assume that the tension spring within the derailleur does weaken with age, so could this be the cause? I also wonder if I have mistakenly put the derailleur back on at the wrong angle i.e. without tensioning it against the spring, but that doesn't seem very likely because there is a pivot stop on the housing to stop you doing that.
My guess is that the spring within the derailleur needs tightening or replacing, but before I try my circlip pliers and short sight on it - or more likely open my wallet at the LBS - have I missed something obvious?
