- London
I've had reason* to check this out and on the web/webshops have seen the depth of the spacer to go behind the 7 speed cassette given as 3mm and 4.5mm. Which is it?
* I bought some new wheels for a 7 speed bike last September, fitted the 4.5mm spacer that came with them, have just realised that the odd rattling I was aware of in certain gears (I can be a bit leave-well alone with niggling mechanicals) I was hearing in the odd gear was the chain rubbing against my frame (steel so hopefully no real significant weakening of it) when it's on the smallest rear cog. Maybe a smaller spacer would solve this?
I think my rear wheels is currently fitted with this, though I got it from Spa Cyles with the wheel.
http://www.sjscycles.co.uk/wheels-m...te-on-8-speed-hub-body-spacer-each-prod18561/
No cut outs, though I have seen some with cut-outs.
This is 3mm
http://www.wiggle.co.uk/shimano-cas...ano-Shimano_Cassette_Alloy_Spacer-Silver#more
Yes, I know it seems barmy that I've only just noticed but not ridden it too much.
Or could something have happened to the wheel dishing that has caused this?
I use SRAM cassettes but surely this makes no difference? I thought that the key dimensions were the same as Shimano.
This is 3mm
