I happened to be passing the LBS, so dropped in. Dent isn't an issue, but the rim is quite worn, so will replace anyway. Bought the wheels in September, and have done about 2,500ish miles through the winter (mainly London commuting). The rims are H Plus Son archetype - is that "normal" wear? The front rim is fine & has loads of wear left. Must mean I use the rear brake more than I thought I did!!
