Deleting posts
corshamjim
Corsham
fwiw I deleted a post a couple of days ago no problem (using Firefox on Linux). I'll try deleting another one now to be sure.
... later ... no that deleted fine. I had a warning it would still be viewable by the moderators then deleted no problem. It might be worth clearing your browser cache then try again.
Shaun
Founder
There's problem with the software that will be fixed in the next release - it shows two delete options - the user/moderator "soft" delete button (on the right), and the admin "hard" delete button (on the lower left).
Use the right-hand button and it should work fine.
Cheers,
Shaun :biggrin:
Haitch
Flim Flormally
Netherlands
Sorry, Shaun, I'm probably being thick, but I only see one delete button - it's on the bottom right next to "edit", "reply", and "multiquote". That's the one I used.
It just worked for me. Press the delete button attaching to the message and a box comes up with two options, Remove and Delete. Clicking the Remove button does what it says on the box.
So what incriminating text did you want to expurgate?
