GuyBoden
- Warrington
DELETED
Are the BB shell widths the same? I'd expect the road bike to have a 68mm wide BB shell. Whereas the H2 MTB spindle will be designed for a 73mm wide MTB BB shell. Forgive if wrong. 5mm seems a lot of washers, to me.
yep - i bought a bike with HTII by mistake not really considering the BB.I tried fitting an MTB HT11 triple to a roadbike frame when building a bike for my son. Despite putting loads of spacers on the NDS (less than ideal for BB shell thread engagement) I still couldn't get the chain line to allow the front mech to shift onto the big chainring.
In the end I bit the bullet and bought a bargain road triple with square taper BB from Spa Cycles and it runs like a dream. Square taper is far superior system anyway so don't be tempted to 'upgrade' to HT11.
Hollowtech is a nice system to work with but the bearings don't last quite as long as a sealed square taper unit though unfortunately.
Fair enough, I've found the left bearings tend to go after about 4k miles, the right hand invariably outlasts it. Anecdotal I know, but I've heard other people say similar that the bearings don't last as long as a fully sealed unit. I'd expect a BB-UN55 to last well beyond 10k miles.I agree my Hollowtech setup is 10 years old, 112,000 miles original BB etc Rubbish durability.
I put a triple chainset from Spa on my CAAD5 and I have a similar problem. Next time I buy a BB for it I will buy one with a slightly longer spindle. For now, the work-around is to change to the smallest chainring before venturing up onto the biggest few sprockets. (The extra lateral bend in the chain helps the front derailleur peel the chain off the ring.)One of my ridgeback hybrid conversions got a Spa road ST chainset - a problem with getting the chain to drop onto the small ring was sorted by just using a ST BB with a 2mm longer spindle - problem solved for evermore. Simples.
your posts are a tad confusing mr ming. You said you consider ST to be far superior to HTII.I agree my Hollowtech setup is 10 years old, 112,000 miles original BB etc Rubbish durability.
i'd change it now.I put a triple chainset from Spa on my CAAD5 and I have a similar problem. Next time I buy a BB for it I will buy one with a slightly longer spindle. For now, the work-around is to change to the smallest chainring before venturing up onto the biggest few sprockets. (The extra lateral bend in the chain helps the front derailleur peel the chain off the ring.)
