Bodhbh
I was hoping to get my winter commuter running smoothly around now, but there's a nagging problem with the rear shifting...
It's a 9x3 speed deore setup with trigger shifters. The problem is the gear change will be delayed a long time after I shift - sometimes a few seconds, sometimes minutes later, sometimes never. This is the same both for up and down shifts. If I want to reliably go up or down a gear at the time I make a shift, I have to double shift, but I may get a shift further down the line. So for I have check/tried:
- changed cables. I've checked for friction, seems fine, the mech moves immediately when I shift.
- indexing, fiddled around with it a fair bit, no improvement. In fact it seems good, with no noise or jumping.
- chain length seems fine - if anything maybe a tad short - agewise prolly a couple 1000 miles on it, same as the rest of the drivetrain.
- mech lined up straight, hanger not bent
- b-adjustment screw tried at both extremes, seem a little better when it's slacked off, but it's never good.
- cassette on tight, no play there.
Any further ideas for things to try? Next step is prolly a new mech. I've not got a spare one handy to swap and check.
