Hi everyone,
I'm just after a bit of advice about repairing my tyre... yesterday I discovered I had a flat. I've pulled the inner tube out and pumped it up. It looked fine and there was no sign of a puncture and it stayed inflated but my track pump wasn't registering any pressure even when it was fully/over inflated.
I let the inner tube down, re-inserted and then pumped it up again.
This time, the track pump still wasn't registering any pressure and it instantly started deflating (hissing quite loudly) from the valve.
I assume this means there's an issue with the valve and I need to replace the inner tube but has anyone got any idea why the valve only starting leaking when the tyre was on the rim?
Also, I have a bike with hub brakes and hub gears. Anyone got any hand hints for taking these off so I can get the wheel off or do you think I should get it to a bike shop and let the professionals have a look. I guess if there's a problem with the rim, it would make sense to have the pros looks at it anyway.
This is the bike, if that helps: http://www.edinburghbicycle.com/products/revolution-heritage-deluxe-13
I've had it around a year.
To give you an idea of my bike fixing skills, I can fix a puncture but that's about it! Anything more complicated and I'm lost.
