I've replaced the cable inners, outers & ferrules to both my front & rear mechs The front however just does not seem to want to play properly. The cable seems to have a really high ammount of tension in it to get it to work, I can't turn the barrel adjuster at all because of this. To get the chain onto the outer ring you have to play with the gears on the back (had to do this prior to cable replacement as well) as well as having to change down to the smallest ring in order to change to the outer ring (won't change from middle to outer). Any ideas anyone ?????
