Alembicbassman
Confused.com
I took my wheels into my LBS to get the bearings greased. The rear wheel came back with the freehub catching the locknut on the cone.
The wheel was running freely when I took it in.
I raised this with the guy in the shop who took off the cassette and showed me the end of the freehub was bent.
He said it hadn't been pressed in correctly from manufacture.
This is a Shimano 8 speed hub from a 105 groupset.
Are these freehubs easy to damage if you try to grease the cones without remove the cassette?
Could a large screwdriver be used to immobilise the axle on the cassette side whilst removing the cone locknut on the opposite side? This would be one way to explain the bending of one side of the freehub body
The end of the freehub where the cassette locking collar fits into is now bent and fouling the cone locknut.
The guy in the shop seemed to infer that the technician who removed the axle may not have removed the cassette before greasing.
The shop want to charge me £20 for fitting a new hub. I am reluctant to pay this if the damage was caused by the technician.
The wheel was running freely with no binding when I took it in. The binding after the greasing was very obvious. There were no witness marks on the locknut to indicate binding either.
I don't know a great deal about bikes but when a wheel comes back worse than when you took it in makes me think something went wrong somewhere.
