cycling shoes
woodbutcher
S W France
I have a confession to make....l have never owned or worn a pair of road bike cycling shoes.
I am thinking about getting a pair but l just wonder if there would be any great advantage when riding "ye old "steel machines, over my normal beaten up trainers ? Any views or advice would be much appreciated:bicycle:
mjr
Probably not AFAICT. If you continue riding flats, maybe with clips, then probably not, as long as your current pedal platforms are large enough to support your feet, or if you switch to clipless, then probably not because the much-vaunted stiffness is basically to compensate for the smaller pedal surface.
Deleted member 35268
Have a read of this article.
If you buy some road shoes there are two types, SPD-SL or SPD
Depending on which you go for you'll obviously need to get new pedals to match.
bigjim
Manchester. UK
Riding flats whilst wearing trainers causes me to suffer from sore tendons. The soft flexible sole and heel of a trainer allows the heel to droop over the rear of the pedal, stretching the tendon. A stiffer soled shoe eliminated this problem. I'm sure not everybody has this problem. We are all different.
mjr
Yeah, all different: I used to wear stiff-soled shoes but ended up with tendonitis in my toes which has been relieved by switching to a softer-soled shoe... but to be fair, I suspect the shoe had gotten too old and wasn't cushioning my toes against the leading edge of the pedal enough any more. My feet are large enough that the toes would probably hang over the front even of MKS lambdas.
woodbutcher
woodbutcher
S W France
I think l will wait awhile before deciding what to do but in the meantime l will get some overshoes and hope they will fit ok with being clipped into flats.
pjd57
Glasgow
I don't use clips or straps but do wear fairly basic cycling shoes.
Harder soles feel better and it saves wear and tear on my other footwear.
Specialised shoes start at about £25 on Amazon
simongt
Norwich
My choice for most of my steeds are the Shimano M515 SPD pedals with associated footwear. Very easy to use and the big plus is that with SPDs, you can walk for a reasonable distance off the bike and apart from the built in stiffness of the soleplate, you hardly notice. :thumbsup:
booze and cake
probably out cycling
These are quite expensive, but on 'sale' and if you want some classic, vintage looking cycle shoes with SPD fitting, you can't do better than these I think. I've had a pair since 2010 and they are still going strong. I'd advise ditching the waxed laces for some normal laces but otherwise they are super comfortable and durable, and look great, and with a bit of polish buff up like lovely conkers.....and you'll feel like Fausto Coppi^_^
https://dromarti.com/cycling-shoes/sportivo-classic
woodbutcher
woodbutcher
S W France
Now you've done it ! l shan't rest until l have a pair in my hot little mitts. They are lovely and what about those bikes ....drool :hyper:
