potsy
Rambler
- My Armchair
Have read a few good things about those on here and will keep them in mind if I do pluck up the courageSittingduck said:Get M520'sDouble sided - so no flicking and very easy to clip in/out.
potsy said:Might be a daft question but can you wear SPD shoes for cycling on normal flat pedals?
If yes what are the advantages over say a pair of Nike running trainers that I wear now?
Cheers.
potsy said:Well, took the toe clips off last night and really regretted it on my commute today will be going straight back on tonight.
Feet seemed so unsecure on pedals.that couple of seconds to get in the toe clips seems insignificant now
Thanks Arch,to be fair I was getting used to them I think, just didn't realise it, as my speed has increased since I fitted them going back to no clips was really annoying foot slipped completely off pedal twice.Arch said:I have toeclips on my FCR, the moulded plastic type without straps, that just hold your toe in. I find they pretty much swing to the right position anyway, thanks to the centre of gravity. I was out on Sunday, and when my feet started to hurt I wanted to ride out of the clips for a while to vary my position, and found it actually quite hard to keep the pedal from swinging back and engaging my toes again... So do persevere, it'll become second nature.
And I wear SPD shoes for long rides (I bought them for using on my recumbent trike, where clipless really is a must to prevent your feet slipping off), the stiffness does help. Day to day I use ordinary trainers.
