top-tube
- Leith, Edinburgh
Cycling out to Forth Road Bridge on Saturday, I took the NCN 1 which follows the A90. Between Cramond Brig and Dalmeny, the cycle path is essentially the footpath by the A90. I hit a 'speed bump' in the path, caused by a tree root growing under the path, which had lifted the height of the tarmac to form the bump: this was also a shaded section so visibility not great in the drizzle. Lost control after going over the bump, and ended up crashing into the verge about 10 yards on.
Grazed my thigh, shredded my shorts, and my beloved Raleigh Pursuit strangely 'gave' on the top tube and down tube just behind the head tube, bending back the head tube and forks and effectively significantly shortening the wheelbase: strange the forks didn't give way instead of the main frame.
Anyway, frame was cheap ebay purchase (£31), Aldi shorts (£8), so not much lost financially, and in terms of injuries, it could have been a lot worse. Managed to limp home, but the frame is a write off.
At the very least, I think I should write to the council (if they are responsible for footpath maintenance) to alert them to this potentially dangerous stretch of cycle lane. I'm not a litigious person, so don't intend pursuing for anything else.
Any advice please on who is responsible for cycle lane upkeep, and what I should do?
