on my Cyclosport computer I use 2174.
But you can measure it yourself by; marking the the floor using the valve as a starting mark, roll forward until the wheel has done one full revolution. Mark floor again. Use tape measure to measure between the 2 points, you should get your factor (in mm's). Should give you an accurate reading.
