Cycle Computer with Odometer Setting on Battery Change
roubaixtuesday
self serving virtue signaller
I've got a couple of Cateye computers, one of which is ancient and has the ability to set the odometer, the other, newer one doesn't. Not being able to set the odo when changing the battery is annoying - they last about 5,000 miles then zero on battery change.
I've a need for a couple of new ones (tandem, plus new road bike), ideally keep Cateye just so functionality is more similar.
Does anyone know which, if any of the current range https://www.wiggle.co.uk/cateye/cycle/computers/ allow odometer setting? It's not obvious to me.
If not Cateye, any recommendations?
I don't want cadence, power, gps or anything fancy, just speed, av speed, odo.
wajc
I remember buying an old Cateye Enduro 8 for the same reason some time ago.
From the Cateye manual it looks like both the current Velo 7 and Velo 9 allow you to input an odometer reading. Same manual for both models, Velo 7 looks like the one for you as it doesn't have carbon offset and calorie consumption of the Velo 9 (which I'm sure is a load of bull anyway)
Cateye Velo 7/9 manual
