cube sizing
BigonaBianchi
Yes I can, Yes I am, Yes I did...Repeat.
http://www.coventrycyclecentre.co.uk/m21b0s6p4787/CUBE_Agree_GTC_Race_Compact_2014
I'm trying hard not to fall head over heals in lurve with this little lady...
...I'm torn between a 62cm and a bigger one.
I'm 6'4" and my bianchi c2c compact is a 61 frame . It has a 120 stem and lots of seatpost on display. I'm comfy on it but it looks small on me.
The cube sizing chart suggests I need a 64 ...but I have no way of comparing the bianchi size with the cube size...I mean are they like for like?? Suspect not.
I can't find a dealer close enough to test ride and even if I could I'd bet a lot of peanuts they won't have anything but midget sizes in stock.
I know its impossible to be accurate on info in this post but please five me your best guestimate and thoughts.
Ta very much :smile:
BigonaBianchi
BigonaBianchi
333
If its of any help to you, with the recommendations on here I bought this one yesterday (delivered next Sunday):
http://www.leisurelakesbikes.com/p/14380/cube-peloton-race-compact-racing-road-bike-2014
I also looked at the GTC you have linked above (in the shop), the frame size I went for was 62cm (I'm 6ft 3.5/6ft 4) and it fit me perfectly in the shop, I'm pretty sure (someone correct me if I am wrong) that 62cm on the Peloton will be the same size as the GTC?
Its a nice bike and I was suitably impressed with it (the GTC) but unfortunately they didn't have my size as it was a sale bike.
BigonaBianchi
BigonaBianchi
Looking at the two specs the dont seem to be diectly comparable on just a 'frame sze' basis.
Looking at the top tube length between centre of steerer tube and seat post I THINK the bianchi 61cn frame has a 57.2 cm vs. the Cube 64cm frame at 57.4 reach.
I cant seem to get a comparable wheelbase length.
BigonaBianchi
BigonaBianchi
looking at the seat tube length the bianchi 61cm frame has a 58cm seat tube, the 64cm cube frame has a 60cm seat tube.....given my existing seat tube on the bianchi fully extended Im starting to think a cube 64 frame is nearer the mark......'why are these things never clear?" - Captain Jack Sparrow lol!
BigonaBianchi
BigonaBianchi
Thanks.
Looking at the charts the Agree has a slightly different geometry to the pelaton...the top tube is slightly longer so the reach is as well....
Im sure i could set either a 62 or a 64 agree up to be comfy to ride....I just dont wan tto much seat post, but then again I dont like the look of a massive head tube either...my galaxy is a 64cm frame and that got me across the states....but the geometry is again different to both the bianchi....
anyone got a coin????
Deleted member 23692
Doing some maths on the Bianchi dimensions, the wheelbase comes out at 1012mm on their 61cm frame. The Cube is just a tad shorter at 1008mm (62cm frame)
U
User6179
The 62cm will have a larger drop between seat and handlebars , personally if I am between sizes I go up the way for less drop .
BigonaBianchi
BigonaBianchi
the cube 64cm fram has a 1018 mm wheelbase,,,,so im thnking it needs to be no shorter than the bianchi.......erm...so its looking closer to a 64 than a 62 frame i think for me.......
