CUBE AIM SL 2018 rear end conversion from 135x10 to 142x12
Petronio
Hello!
Lately i was looking for more info about my bike (CUBE AIM SL 2018) conversion from standard QR (135x10) to through axel (142x12), and so far i couldnt finde any conversion kits for it....maybe anyone know any universal conversion kit to solve this problem?
Ajax Bay
East Devon
:welcome:
What problem, exactly? Or is your name a clue: Petronius was credited (apparently without foundation) of saying that reorganisation (in this case trying to change from QR skewers to a thru' axle) can be a wonderful method for creating the illusion of progress.
How will your dropouts suddenly widen out to 142mm from 135mm?
Petronio
Petronio
si_c
Wirral
The difference is that these bikes and wheels were designed to be interchangeable with different standards. In the second video you see them changing the dropouts for the alternatives, so the bike had wider spacing to start with. Unfortunately with your bike it has 135mm spacing and fixed dropouts so you can't change anything.
There is nothing wrong with a QR system though, is there any particular reason you are trying to change?
Petronio
Petronio
Well i'm trying to achieve more stiffness in my rear, so i thought it would be a great place to start....but it is what it is... :sad:Thank you for info!
boydj
Paisley
Unless you're capable of producing professional levels of power, you'll never notice the difference.
si_c
Wirral
Widening the rear triangle won't necessarily give you more stiffness, if the backend is loose make sure the rear wheel bearings are set correctly and that your spoke tension is adequate.
