arallsopp
Post of The Year 2009 winner
- Bromley, Kent
SOLVED: Creaky Time Atac Alium pedal (was retention spring)
Howdo.
I've got a pair of Time Atac Aliums, and after around 600 miles the right hand pedal seems to be developing a hollow sounding "crirrink crirrink' sound once per revolution. The pedal spins pretty smoothly, and there's no clunking or anything ugly felt.
I can make the sound go away if I twist my right foot a little, and it only seems to happen under load. If I clip out and pedal with the left foot only, it seems to go away too, but its hard to get a similar push with only one leg up
Once it starts, it tends to stay for the rest of the ride, and its starting increasingly early each time. I can't work out if its the cleat engagement, the pedal bearing, or the bike frame acting as an amplifier and transferring noise from the BB/frame/elsewhere.
The bike is a recumbent SMGTe with about 1000miles on it. I'm pretty sure the sound comes from the pedal, but oddly the right hand pedal is the one I leave clipped in at junctions. If I remember, I'll take her out for a spin without my proper shoes and see if the noise goes away.
Can't see any way to open the pedal and get at the bearings, but then, I have the engineering instincts of a bowl or cereal.
Howdo.
