Based on your detailed description, my advice would be to fix it so it stops creaking.Noticed my bike develop a creaking noise when pedalling, sounds like it’s coming from rear, any advice please?
Clean and re grease seatpost and clamp. Same with cleat bolts. Then test.
No point in fixing the seat and seat post if it creaks when you are standing up????
although I have seen creaks that happen when pressure is released
so try riding under power but standing for severl revolution of the pedals - if it still creaks then it ain;t the seat
probably
creaks can be weird
I recently put a new seat on the bike and creaking started after so will check this, thanks.Stand up and pedal... does the sound go away? If so, you may have similar problems to me. I had it on a bike recently, two causes...
Those changes fixed the problem for me.
- The saddle clamp bolt was a bit rusty so I hadn't managed to tighten it enough. I lubed it and then got it tighter.
- The saddle itself had a loose rail where it went into the back of the saddle. I swapped the saddle for one from my turbo trainer.
