mynydd
Hi, I'm after some advice please. Following on from this:
http://www.cyclechat.net/threads/annoying-creaking.138335/#post-2620927
Unfortunately the problem wasn't solved, so I returned the bike on friday and they replaced the crank. All seemed good and I thought that was the end of it.
Then..... On my ride home tonight the bleeding creaking started again! Same side, each pedal rotation. Nothing if I pedal only with the right foot clipped in.
Should I ask them to change the bottom bracket do you think? I'm pretty fed up now and am spending a fortune driving back and forth to the shop.
Thanks
Thanks
