stuarttunstall
- Yorkshire Wolds
Hi
Over the last week I have had a spoke replaced in the back wheel and replaced the brake pads front and rear...
Since then I have notice that when I start to pedal there is a clicking/rubbing sound when is start to pedal or when going up a hill which seems to come from the pedal/crank area..
I have just been out and released the QR on both wheels, checked that the bolts on the crank and rear derailleur are tight which they are and made sure the QR's are tight..
The sound seems to be more in low gears and goes as I speed up or change up gears ...
Any ideas?
I am sure it is to do with either the new brake pads, maybe rubbing the disc or the removal/refit of the wheels as this is the only things that have changed.. It does sound drive related.
Stuart
Any ideas?
Stuart
