Hi, I bought this crank puller with the hope of using it on my Raleigh Stowaway 7... I've removed the caps, taken off the nut and attempted to attach the puller. However, the outer sheath of the puller (the bit which you screw into the crank) doesn't extend past the plunger (the bit which pushes against the bolt inside the crank). This wouldn't be a problem, but the crank bolt sits flush inline with the edge of the crank meaning there's no way at all to screw the puller in even a thread or two.
Is this normal for a puller? Am I doing something stupid? The photo shows the puller FULLY EXTENDED.
I'm not sure what bottom bracket configuration I've got so perhaps I've bought the wrong puller. If someone could tell me how to find out whether I'm square tapered, octalink etc I'd appreciate it.
