Crank arm falling off
Trickedem
Kent
My 105 crank are keeps falling off
Before my latest ride I tightened it up and uses threadlock, but 5 mins into the ride it fell off
This is the third time this has happened. Any tips appreciated.
I was thinking of getting some longer bolts and putting some nylock nuts on.
512466
512467
512466
512467
DCLane
Where's the end bolt - the "crank fixing bolt"?
Also, there should be two allen key "crank arm pinch bolts" to tighten it on plus a small tab - a "crank retainer" - which stops it falling off. Are they there?
Trickedem
Trickedem
Kent
The little tab was there. I bought some new ones, when it first happened. But I think they are fairly ineffectual as it is only a little pin. The bigger issue seems to be the bolts are not tight enough, maybe the thread on the arm is stripped
Gunk
Oxford
A complete 105 crank arm isn’t much money, I’d just replace it, sounds like the threads are stripped. I’ve never had one come loose.
rogerzilla
I don't think my only HT2 crank has the tab washer there, and never did. It's a secondary retention device which just stops the crank completely detaching if the two pinch bolts come loose, and should never really come into play.
