What's your opinion on this. Is this crack fixable, and if it is how...
lilolee Guru Location Maidenhead 28 Oct 2020 #1 What's your opinion on this. Is this crack fixable, and if it is how?
cougie uk Guru 28 Oct 2020 #4 I think they'd need to replace that joint completely. Any Alan dealers near you ?
midlife Guru 28 Oct 2020 #5 Not seen a new ALAN for sale in many a year . Maybe some aluminium welding is in order?
OP OP lilolee Guru Location Maidenhead 28 Oct 2020 #6 cougie uk said: I think they'd need to replace that joint completely. Any Alan dealers near you ? Click to expand... I believe the nearest is in Holland
M MichaelW2 Guru 28 Oct 2020 #7 Is your seatpost too slim for the frame? Seems to be a lot of compression on the clamp. Some people have had a cracked lug re welded but it needs some expertise.
dan_bo How much does it cost to Oldham? Location Not fkin Failsworth or fkin Blackpool either 28 Oct 2020 #9 lilolee said: I believe the nearest is in Holland Click to expand... speak to Zepnat in Matlock they *may* be able to help.
