Cotter pins
Chris S
Birmingham
I will probably have to renew the cotter pins the next time that I take the cranks of my 1970's Raleigh.
I've noticed on ebay that there are three sizes: 9mm, 9.3mm and 9.5mm.
Does anybody know what size I should use? My bike has a chainring similar to the one in the picture, instead of one with the usual Raleigh herons.
Ian H
Ancient randonneur
Sit yourself down and have a read: https://www.sheldonbrown.com/cotters.html
Gunk
Oxford
Use a wooden block with a large hole drilled in it to support the chainset, it’s much easier to hammer the pin in using this method, otherwise all the energy is transferred to the frame.
tyred
Ireland
They need to be hammered or pressed in again too. The nut only holds them in place. The thread is nowhere near strong enough to pull the pin into place.
