plastic_cyclist
- Angus
Yes they ( the Halfords ones ) will be fine.I’ve had a bike handed down to me and I recently changed the tubes (tyres are Specialized borough 700/32C).
I ordered some of these to cover the 700 and 32 Tubes
However when I removed the old one I noticed the details on the side....
Was this the wrong tube or do both of these fit this tyre ?
You really need to check the inside of your tyre for anything sharp that has remained in situ.Well, the reason I asked was because yesterday, I was using the bike no problem, not on a ride but just patrolling the village to keep an eye on kids biking around etc....and then today, I went into garage to retrieve bike and I had a flat !! replaced the tube and I had another one go on me straight away, literally seconds after I put it on !! bizarre. Dodgy Tubes?
yes. run finger round inside about 6 times. And with the tyre flat squeeze the outer to see any embedded thorns or stone/glass. Pick out with a sharp pointYou really need to check the inside of your tyre for anything sharp that has remained in situ.
Find the puncture in your inner tube and this will give you a good idea as to where to look in the tyre.
Edited to add - when you refit the tyre, try to line the logo up with the valve - that way you can narrow down where to look if you get another puncture.
I align tyre pressure max /min embossing with the valve stem not cosmetic but the practical info you needIt does make sense to do this as a reference point for searching for penetrating objects, and the sight of a Schwalbe fitted with a misaligned logo is probably enough to cause a few fellow cyclists to have OCD episodes.
