Snorrarcisco
Regular
- Kent
I was watching this video on you tube of someone doing the conversion between a centre lock to 6 bolt bearing discs. Now he gently applies what looks to be copperslip on the thread of the wheel section (the shimano centre lock part) and then inserts the converter on it.
Is this necessary? in what ways and where do you use copperslip if you use it at all?
