Hi,
As I have posted in the fixed forum I have a bike I want to convert from road to fixed...The more I read up though, the more I am getting confused.
If you could give me some advice I would be very appreciative.
1. I believe I can convert to fixed on a vertical dropout bike so long as I use a chain tensioner to make sure the chain is tight?
2. I have a hub which is 6 speed shimano uniglide that i was told is of the threaded variery...Can I use this ok?
3. Using this hub do I still need to get the rear wheel dished for single speed..if so, why?
4. How do I get it so the chainline is correct..Do I put spacers before the sprocket to space it out to align with the chainring, then put the sprocket on and a lockring?
Any help would be greatly appreciated.
Thanks Ahead
Dan
Thanks Ahead
Dan
