Converting to Campy CT; any advice?
DeBonc
Am thinking of converting my 9-speed Campy drivetrain to a 9-speed Campy CT (or... I could drop a few stone but who wants to do that, right?! :sad:). Current set-up is 100% Chorus but the CT would be a Record CT front mech, Mirage CT crank, Record 9-speed chain and keep the Chorus rear mech. Simple switch-out or am I missing something?
Thanks!
Will1985
South Norfolk
Sounds ok. Dropping a few teeth is probably not enough to warrant removing links from the chain. Well, maybe one. Is this UT or square taper?
DeBonc
Hmmmm... I don't know actually. Why, does it matter? Thanks! BTW, I ride a Bianchi as well ('07 928 RC)
Will1985
South Norfolk
The newer front mechs can definitely cope with CT or standard, but DeBonc is talking a whole 9s Chorus setup - that's ?5 years old. I thought there was a bit of difference between the cages back then, even if minimal.
On the other hand, will a new Record front mech shift as smoothly with a 9s Chorus left shifter? I forget which way QS works better when mixing.
