Converting 10 speed hub to 11
Jerry Atrik
South Devon
Wondering if you can help ? I've got a set of wheels with a shimano 10 speed hub on but am getting an Ultrega 11 speed groupset . Is there a standard 11 hub out there that I can convert to as the make of wheels ive got have not . I like these wheels and don't really want to demote them as such .
Google 11 speed shimano freehubs, there are some expensive ones, some very expensive ones and some that are around 25 quid on ebay, that should do the trick
What wheels are they ? Mavics will take an 11 speed cassette already as the body is slightly longer. You can't just go swap in an 11 speed on some other wheels as the body is slightly longer and may not fit correctly.
Not quite as simple as it sounds. All shimano's wheels/hubs were modified for 11 speed as the 10 speeds were not compatible.
