Convert Forme longcliffe to flat bar
Please can you advise what is needed to convert to flat bar as I really can't get on with drops
If possible I would like recommendations on good but budget components and then what you may recomended as being worth spending a bit more on.
The bike spec as follows, thanks in advance
Forme Longcliffe 4.0 2013
  • Frame - Forme 7005 Aluminium Double Butted, Mudguard Eyelets
  • Sizes - 53cm,
  • Fork - Forme T700 12 Carbon Blade, 1-1/8" Alloy Steerer, Mudguard Eyelets
  • Handlebar - One23 SL Alloy 31.8mm, 144mm Drop, 77mm Reach
  • Stem - One23 SL Allou, 28.6x31.8mm, 7° Rise
  • Handlebar Tape - Forme Ergofit Cork, Black
  • Headset - FSA No.10, 1-1/8" Semi-Integrated
  • Spacer - Forme Alloy, 3x 5mm & 2x 10mm
  • Bottom Bracket - FSA Square Taper, Sealed Cartridge 68/110.5mm
  • Chainset - FSA Tempo Compact, 50/34T
  • Pedals - Wellgo R090, 9/16" Cr-Mo Axle, Clips & Straps
  • Chain - KMC Z72, Semi-Plated, 8 Speed
  • Saddle - One23
  • Seatpost - One23 SL Alloy, Micro Adjust, 31.6mm
  • Wheelset - One23 Comprising Alex Race 28 Aero Double Wall Rims, Formula RB31 & RB32 Hubs
  • Front Mech - Shimano FD-2300
  • Rear Mech - Shimano RD-2300, 8 Speed, Short Cage
  • Shifters - Microshift SB-R082, 16 Speed
  • Cassette - CSR86, 8 Speed, 12-25T
  • Brake Callipers - Forme Alloy Dual Pivot, 47-57mm
  • Tyres - Kenda K177, 700x23c, Fast-Rolling Sport Tyres
MisterStan
Label Required
I have a set of flat handle bars and also the brake/gear trigger shifters, which you are welcome to if you will cover the postage. These came off my CB when I converted the other way. They are 8 speed and compatible with the remainder of your gear - you'll probably need (or would be wise to use) new brake and gear cables too.
H
Henrythedag2
Thank you I would like to take you up on your very generous offer
Not sure how you PM on here
