Good evening,
I am not a bike frame designer, so does anyone here who is have any thoughts on the different loads placed on the front forks and steerer when it becomes responsible for transmitting the drive forces?
If I ride a normal bike, the bike is accelerated from the rear both the weight of the rider and the bike and the front forks need to cope with accelerating themselves and the front wheel, as well as surviving hitting pot holes and the rider rocking side to side out of the saddle.
If we add a motor to the front wheel then the front forks also become responsible for transmitting a “pulling force” to the bike and rider and in practice this force may cut in and out quite abruptly as the speed limit.
To me the existing loads seem to be much greater than the loads applied by the motor, but the frequency of these smaller loads would seem to be much higher and they will occasionally be added to the worst case for the pedal frame.
So does this new load add up to anything to worry about?
Bye
Ian
