Completed my first cycling clud road ride !
iendicott
Peterborough
Completed my first cycling road ride !
Joined the Fenland Clarions yesterday after going out with them on a winter hack.
Really nice bunch of people and learnt a great lot of info whilst riding along. Clocked up 35 miles and I must say the time flew past whilst in the saddle. It was a great feeling being on the road in a small group. I did have reservations on using my hybrid as I knew most of them would be on road bikes but I managed to keep up.
Only issue is I am a lean build my coccyx bone area gets sore from sitting on the seat. The seat is a Gel one. I have padded leggings and this has helped a little but I need a little more padding around my coxis :biggrin:
Is there any extra padding you can buy to help out as I have a 65 miler next weekend and I don't want to be walking like John Wayne as the wife might get a bit suspicious ;) ?
Thanks Ivan
Ian H
Ancient randonneur
More padding is likely to make matters worse rather than better. But I'm a little perplexed that your coccyx is in contact with the saddle at all. Is it a very soft saddle?
Garz
Squat Member
Down
Try to tweak your setup so there is less pressure at that contact point. If needs be a proper bike fit may solve it. It does take a few weeks of distance rides to overcome the saddle sore sensation, your body will adapt.
ColinJ
Puzzle game procrastinator!
I can't see how the coccyx would be touching the saddle either. I reckon it is more likely to be the perineum that's the problem. It's not far from the coccyx, but at least it does actually touch the saddle.
Keith Oates
Janner
Penarth, Wales
We are not all built exactly the same I know but for me I find the Gel saddles uncomfortable for longish rides. Try getting a less padded roadie saddle and you may find that's better for you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
iendicott
iendicott
Peterborough
Cheers for the advice.
I have looked at a few diagrams and it appears it the bottom part of the Pelvis bone I think it's called the Ischium which can be seen here
I have tried the ride with it and it will get better but to be honest this has not made a difference.
iendicott
iendicott
Peterborough
Tynan,
Yes as the bike is a hybrid it's difficult not to as the frame is quite short from seat post to steering stem, I have up'd the seat by about 3 inches as aparently going by the book I have just bought you should be able to straighten your leg fully when sitting on the seat and I couldn't so it might be bad posture. This may help me by leaning forward a ouch more possibly.
When I bought the bike the guidance size suggested I needed a large (21") which went to 6' I am 5'11.
Tynan
e4
I'm no expert at all but even small changes in saddle height, position and angle make real differences. ditto handlebars although I've never touched them
cleats too if you have them
iendicott
iendicott
Peterborough
Tynan,
I have move the saddle up a small bit about 1 1/2 inches so I am learning more forward but not to much to put pressure on my wrists.
At some point I have to change the standard track pedals to clipless but I am going to take some time about this as when I get the road bike I will be buying the same clipless pedals for that as well so.
Thanks for the advice.
