Compact Chainsets/Ultra Narrow Chains
threebikesmcginty
Corn Fed Hick...
...on the slake
Just after a tad more info if anyone could assist.
Do you have to use an ultra narrow chain with a compact chainset?
Are there advantages other than weight?
That special tool you need to fit one seems bloody expensive!!! :smile:
Thanks in advance folks.
John the Monkey
Frivolous Cyclist
Crewe
The "Compact" refers to the fact that the chainrings have fewer teeth than a standard double chainset (e.g. 50/34 as opposed to, say, 52/42)
The chain width is dependant upon how many gears the bike has. 9 and 10 speed (and I assume 11 speed) drivetrains need progressively narrower sprockets to accommodate the extra gears on a 130mm spaced freehub wheel. In turn those narrower sprockets use a narrower chain.
