nickg
- Colchester, Essex
Im looking for a co2 pump. Now I have a few questions about them. How do you control them once attached to the valve? How do you know you not over inflating the tyre? threaded vs non threaded?
Generally you choose the cannister size for your tyre /wheel type, a 16 g will inflate a road tyre to around 100 psi which is about spot on .threaded or unthreaded just depends on what your make of inflator takes as some screw in or others are held in place by a case .Im looking for a co2 pump. Now I have a few questions about them. How do you control them once attached to the valve? How do you know you not over inflating the tyre? threaded vs non threaded?
Well ive just ordered a pump
http://www.wiggle.co.uk/genuine-innovations-ultraflate-plus-co2-tyre-inflator/
along with some co2, tyre levers and a couple of spare tubes.
in the market for a co2 inflator looking at this one looks great but wiggle have it as discontinued anyone have surggestions as to the next best thing?
Thanks - http://www.tyreinflators.co.uk/index.php?act=viewProd&productId=1137&category= i run 23mm tyres normally at 115 (front) and 120/5 psi (back) i know that with co2 you need to release and pump back up when you get home/ to a track pump as co2 escapes? but how much does a 16g cartridge do?
it depends which brand you ask! 16g cylinder will get you between 100 psi and 130 psi for a 700x23 tyre depending on who you believe - I have found with various brands that I never get more than 100 psi fully discharged.Thanks - http://www.tyreinflators.co.uk/index.php?act=viewProd&productId=1137&category= i run 23mm tyres normally at 115 (front) and 120/5 psi (back) i know that with co2 you need to release and pump back up when you get home/ to a track pump as co2 escapes? but how much does a 16g cartridge do?
