Can someone give me some advice on clothing please? I have, up until now, been quite happy with cycling in a t-shirt and shorts, or track suit trousers. Going to be taking on a longer ride soon however and want to be prepared as possible but not as far as 'all the gear and no idea' if you see what I mean! Specifically, do you wear anything between a base layer and waterproof/windproof jacket? Or does it depend on the weather, adding or removing layers as you feel cold/hot etc? If so, what layers are suggested - looking at clothing on wiggle etc gives a vast array of options. Will be dropping into my LBS this evening or tomorrow but don't want to get the 'buy one of everything sir' advice that I suspect I might get.
I have ordered a pair of proper cycling shorts but not sure if I will be brave enough to wear them when out and about with others - my derierre is not the smallest in the known universe and I know I wouldn't want to cycle looking at it wobbling in lycra so don't want to inflict the sight on anyone else either
Normal shorts over the top are a possibility, but if its cold and I put a tracksuit on over that I think it will start getting a bit bulky and restrictive.
Cheers, Steve.
Normal shorts over the top are a possibility, but if its cold and I put a tracksuit on over that I think it will start getting a bit bulky and restrictive.Cheers, Steve.
