cyberknight
- Land of confusion
2 pairs decathlon "5" shorts
http://www.decathlon.co.uk/cycling-shorts-500-flat-id_8165635.html
a bit to big for me now so i get a bit of chaffing from loose fabric by the pad , i dropped under a 30 waist so i reckon these would fit someone more 31-32 , hardley used.
rrp £24.99 each
£8 each or £15 posted the pair
2 SS jerseys
Large medium`s so more like 40 than 38 "
£6 each posted or £10 the pair
Worn RH 8 speed 2300 shifter
LBS said its worn and needs to be pushed further than normal to shift to a bigger sprocket , spares/ repair or hack?
£10 posted
M530 pedals
Used for about 8 months ? , scuffs from shoes etc but bearing in good order, white
£10 posted
8 speed long cage rear mech
A bit grubby but seems to be working ok
£6 posted
Small oversized stem 80mm i think
Off the subway, replaced with a longer stem
£10 posted
Space grip
£8 posted
Bottom bracket
Not to sure about this , given it and was told its a campag BB 115, 5 JIS is what it says on it
£6 posted
rrp £24.99 each
2 SS jerseys
£10 posted
M530 pedals
£10 posted
£6 posted
£10 posted
Space grip
£8 posted
Bottom bracket
£6 posted
