Cloth bar tape wrapping tips
RedRider
Pulling through
I used velox tape to wrap top to bottom recently. I really like the look and feel.
I used this video as my guide but found the tape only just long enough ie I had to wrap and 're-wrap a number times and even then there was not enough to tuck into the bar end.
I had to discard one roll because it became too twisted. I suspect there's a more economical way to go around the hoods.but what do you think? @raleighnut ?
raleighnut
Nice, :becool: I never wrap the clamp that much though.
Loch side.
With plastic tapes we tend to start stretching it a bit towards the end when we see it won't make it. Your tape wont stretch, so you have to eyeball it a bit better. I would firstly start further away from the stem. You want to give yourself as much length as possible around the brake levers. Even a tiny little triangle of visible bar will get you expelled from the ellininati or whatever that secret style mafia is called. I never err there, not 'cause I'm scared of them, but because I can never sleep if I know I missed a spot.
It doesn't seem to me that you first glued a short bit of tape to the lever clamp before starting to wrap. You can cut that from your discarded roll.
Loch side.
But hey, you ride with SPDs, why not proper modern tape too?
Dogtrousers
Kilometre nibbler
Nice job
In ye olde days I used to do a vertical turn around the base of the brake levers (IYSWIM) so the base of the levers was covered. I typed several sentences trying to describe this but they were all rubbish, so I give up. However I didn't have rubber hoods and only had skinny "red dot" levers not big gallumphing brifters.
Back then re-taping my handlebars was something I used to do rather more often than necessary, just because I enjoyed it. Which is a bit of a tragic indictment of my youth. "You coming down the pub?" "No, I've got something important to do" "What?" "I've just bought some handlebar tape from Halfords!!"
RedRider
RedRider
Pulling through
Nice job
Yeah, it seems cheap enough to do before any big ride really! When I've the funds I'll prob get some old fashioned brake levers/hoods.
U
User32269
Last time I used cloth tape, I still had hair! I've always gone from bottom of the drops upwards. Only because that's how I was taught as a kid, but it always ensures you've got a bit to tuck in.
That looks smart on your bike.
I always wrap bottom to top, if it's a bit short at the top, it's not an issue, being short at the bottom means you don't have the overlap to tuck behind the stoppers.
RedRider
RedRider
Pulling through
Well, I like a very thin tape, I decided to try cloth and it feels and looks good.
Nice Champion Mondial:okay:
I would n't worry too much: you will no doubt be going too fast for anyone to spot any imperfections :laugh:
Dazzling onlookers like golden sunshafts glancing from a jet's wing
